L lzech Dec 31, 2018 6 0 10 Jan 14, 2019 #1 Please tell me if this is safe or if i should find a shorter card. https://ibb.co/0BJkNp8 https://ibb.co/VwVTnDJ https://ibb.co/1mL2jGs
SubaruWRX244 Honorable May 11, 2017 513 0 11,260 Jan 14, 2019 #2 I dont see an issue. You should be fine.... Upvote 0 Downvote
L lzech Dec 31, 2018 6 0 10 Jan 14, 2019 #3 SubaruWRX244 : I dont see an issue. You should be fine.... Are you sure? I dont wanna break the power switch cable bc then i'd be screwed. its right under it. Upvote 0 Downvote
