HELP! Is my gaming PC Build ok?
Unknown673
75
Hey guys/gals I just want to ask you if my PC Build for 2015 is good? I'm going to use this for gaming mainly for skyrim with 4k or 2k graphics mods and assasin's creed: unity on on medium settings or max if it can and fallout new vegas wtih 4k or 2k graphics mod and crysis 3 at max maybe? all of this at a 1920x1080 resolution also I'm going to do some video and photo editing
Question #1 Is my gaming PC Build good?
Question #2 Do I need to overclock it?
Link: http://pcpartpicker.com/user/UNKNOWN673/saved/HjdgXL
CPU = Intel Core i7-4790K 4.0GHz Quad-Core Processor
CPU Cooler = Corsair H100i 77.0 CFM Liquid
Motherboard = Gigabyte GA-Z97X-GAMING 7 ATX LGA1150
Memory = Kingston Fury Red Series 8GB (1 x 8GB) DDR3-1866
Storage = Crucial MX100 256GB 2.5" Solid State Drive
Western Digital Caviar Blue 1TB 3.5" 7200RPM
Video Card = Gigabyte GeForce GTX 970 4GB WINDFORCE (2-Way SLI)
(Note: I'm going to remove the top cage of the case)
Case = Fractal Design Define R4 w/Window (Black Pearl) ATX Mid Tower
Power Supply = Corsair 860W ATX12V / EPS12V
Optical Drive = LG GH24NS95 DVD/CD Writer
Case Fan = Corsair Air Series AF120 Performance Edition (2-Pack) 63.5 CFM 120mm
(Note: I'm planning to add 2 more fans on the case)
Price = $1932.42
P.S. - in my country this is $2,265 , anyways thanks a lot! Comments and ratings are very helpful
Yeah that will be a good gaming pc, but if dong things like video rendering, it isn't needed but I would recommend an i7 due to its hyperthreading technology, I use the I7 4790k with a gtx 970 with 16 gb ram and it is brilliant in any game whilst doing other stuff in background and video rendering. I live in the uk so I don't really know specific price differences in some places ( here computer hardware is expensive ) but in the U.S. there is about an $80 difference between the i5-4690k and the i7-4790k.
Thanks! Question is do I need to overclock it?
also the Intel is 4790k here and the difference is $108 maybe I'll get one in the future
