I am trying to help my brother with his computer. The basic issue is that it powers up, ie lights come on, fans start spinning(sort of), the gpu lights come on, and fans start spinning on those. It sounds like the hard drives are active. But it's not actually turning on. There's no signal to the monitor. The usb ports are completely dead. It's not actually posting. I hear no "beep" to indicate that it has.
Regarding the fans, the two fans on the back of the case are very lethargic. Half the time they don't power up, but then will if I manually give them a spin. This makes me think the power supply is bad.
I have tried a different power cord, resetting the cmos, different monitor, different keyboard mouse, checked all the connections.
Does it sound like a failing power supply or a failing mother board? I've had failing power supplies before but it was quite obvious they had failed-- they were dead.
