Help! K7S5A LAN
bdaley
608
I flashed my BIOS, and everything went fine. Except the onboard LAN adapter's MAC address got wiped out during the flash. Now the adapter won't work.
Apparently this is a known problem since there is a utility file (k7s5a_id.exe) on ECS's web site to correct this problem. The only thing is, I've been trying to download it for two days now and the link is always down.
If anyone has this file or knows an alternate address I can get it at I would really appreciate it.
Thanks!
"There's no such thing as gravity, the Earth just sucks"
I can't do it now, but if you get Download Accelerator Plus and do a file search for that file, you might find it. Make sure it's a reputable site you're downloading from.
<font color=green>I post so you don't have to!
9/11 - RIP</font color=green>
