Question HELP! Lenovo Flex 2-15 not booting.
AlexN.Q
69
4
10,545
Hello people!
I have a LENOVO FLEX 2-15 that will not boot, only if I keep pressing continuously the power button it will start de CPU FAN, gives a long beep and then turns off completely.
I have tried all possible options to get it to work.
  • pull out the battery, 30s press on power button, insert battery back and connected to AC power. (same result)
  • swapping RAM modules. (same result)
  • pulling out the CMOS battery for 1 min. (same result)
  • trying to boot without the RAM or without the CMOS battery.(same result)
All of this option I have tried with AC power only, battery only and both.
Thank you for your interest,
removing the DVD drive and HDD had the same result.
relpacing the CMOS battery with a new one had the same result.
Hey,
Were you able to fix the issue with your laptop? I have the exact same problem with my Lenovo Flex 2-15 and I have tried all the things you mentioned and still nothing. I would really appreciate your help.
Hi, unfortunately I was not able to fix it, but I will try to go with it to a service to see if they can do something to it. I already have another laptop but I don't want to throw it in the trash already.
Reactions: Marjan5
