Here are the two options I'd suggest, overall they perform much the same currently, but the second build whilst slightly over 1500, can be overclocked if you wish and will give you better performance in everything which needs 4 or less cores.
The second build has a much larger upgrade path as you can put in either a kabylake or cannonlake CPU instead of the skylake one which is there now, it also has DDR4 which will be used for all future CPU's for at least the next 4-5 years whilst DDR3 will die out. The second build is the only one where you can put a second GPU in crossfire in future, but by then you are generally better off getting a new GPU instead.
The first build will be better for recording and video editing due to the extra CPU...
