Question Help! low CPU Temps during prime95
z1362110538
I was getting over 90 degrees in HWMonitor, then I clean out my cpu cooler(Wraith Spire) and applied new thermal paste.
Now when I run the same test in prime95, I am getting 65-degree celcius, is this normal?
BTW, I have a ryzen 2700 all stock
Justin Sisti
41
Sounds like you had a really dirty CPU cooler. Make sure you have dust filters on all intakes to prevent that from happening again. Anything below 80C is good, best temps to keep are below 70C.
