[SOLVED] Help M.2 PCIE Trouble
FranticSkunk
11
So I recently bought the Asus Prime Z390-A and didn't read the description when it arrived I noticed that the 2 M.2 Slots are not the same, one is for PCIE M.2s and the other is for SATA M.2s... I have 2 M.2s which are both SATA, is there anyway that I can use my SATA M.2 on the PCIE M.2 Slot?
No. But you can use M.2 to sata adapter. It converts your M.2 sata drive to regular 2.5" sata drive.
