Help Making My System Quiet
psychomellon
63
So here is my system: http://pcpartpicker.com/p/YwwG4D
I wanted to make my system cooler so I added a couple case fans. I didn't have enough fan ports on my motherboard so I got a fan hub. Everything works fine, except the fans are running at full speed so they're pretty noisy.
Is there a way to make them quieter? Should I get a fan speed controller?
You should of bought this instead of the fan hub. I use it I love it. Just surfing the web or witching videos you can turn the speed down then when you need to cooling power then turn the speed up.
http://www.amazon.com/NZXT-Sentry-Mesh-Controller-Channels/dp/B005C31G30/ref=sr_1_cc_1?s=aps&ie=UTF8&qid=1449446426&sr=1-1-catcorr&keywords=nzxt+mesh+fan+controller
Thank you, I will look into this.
If my fans are running at 100% and sound like a loud humming, will 40% make them almost silent?
What powers the fan controller? What port or whateve?
Thank you :)
A 4 pin Molex from the power supply.
http://www.amazon.com/dp/B00IUQRPQS/?tag=pcpapi-20
Does my PSU have that?
So thats a no, I don't have that port then. Too bad lol. Would using an adapter be a problem in any way? If not, from what to molex should I use?
Yes you do have it you got 4 of them.
I'm sorry for being new to this lol.
But how does that 4 round moklex thing in the picture you posted plug into that?
