K kresna889 Reputable May 9, 2014 37 0 4,530 May 21, 2014 #1 can my psu (ENERMAX N400-SA-EU LEPA 400W) handle my rig.? this's my rig amd a10 6790k Gigabyte GA-F2A55M-DS2 R3 (FM2+) Gskill DDR3 PC12800 8GB NT Dual Channel F3-1600C11D-8GIS / 11-11-11-28 Samsung 160GB SATA 7200RPM ty before
Solution S S Smallfilou May 21, 2014 Easily! 250W would even be enough! Actually you could add a gtx750 with the same PSU...
dandn0ten Reputable Feb 19, 2014 754 0 5,360 May 21, 2014 #2 without gpu, it can handle that rig Upvote 0 Downvote
S Smallfilou Reputable Feb 25, 2014 169 0 4,760 May 21, 2014 Solution #3 Easily! 250W would even be enough! Actually you could add a gtx750 with the same PSU... Upvote 0 Downvote Solution
K kresna889 Reputable May 9, 2014 37 0 4,530 May 21, 2014 #4 ty for your advice guys btw 11-11-11-28 is good timings.?? Upvote 0 Downvote
P Pondering Honorable Dec 7, 2013 1,023 0 11,660 May 21, 2014 #5 I am used to at least 9-9-9-24. However if it is one piece of 8GB then it would run slower than 2 pieces of 4 GB or 4 pieces of 2 GB. Upvote 0 Downvote
