Question Help matching RAM
boju
Ambassador
Ddr3 is less fussy than ddr4 so the matching will probably work, maybe at cl10 at worst case. If they all work at cl9 then great, if cl10 gives you stability then that's good enough too and won't notice a difference if it's 1 cl higher.
Mixing ram does have it's pitfalls though and yes ddr3 is less fussy, albeit, no one can give you a definite answer if it'll work until you do.
