Help Me!! Assassin's Creed Syndicate
What spec are you playing on, and what settings are you using? It could be your spec is insufficient or you're not using the best driver or it or the game didn't DL or install well.
Try updating or reinstalling the driver and checking for game file integrity through steam or uplay.
Like I said, it could be not using the best driver. Lately some have reported Nvidia's latest driver is sometimes not as good as previous, esp the betas. Try checking the Ubi AC Syndicate forum or the Steam Forum for the game. There's been some threads on the subject.
Basically what I'm saying is you have to experiment with Nvidia. If the latest one results in weird problems, try rolling back a driver or two.
The latest game ready driver out right now then rolled back to the before that one.
I will check for you when I get home which driver I'm on, I think it may be 358.87 or 91 (one of those two). The game ready driver for mad max I'm on I think.
Regards
