Approximate Purchase Date: Jan 2025
Budget Range: $1,500 - $2,000 (MAX)
System Usage from Most to Least Important: Photoshop/Video Editing, Streaming & Gaming
Are you buying a monitor: No, don't plan to.
Parts to Upgrade: (e.g.: CPU, mobo, RAM) **Include Power Supply Make & Model If Re-using**
Do you need to buy OS: Yes
Please note that if you're using an OEM license of Windows, you will need a new one when buying a new motherboard.
Preferred Website(s) for Parts: Open to suggestions
Parts Preferences: No Preference
Overclocking: Maybe
SLI or Crossfire: IDK
Your Monitor Resolution: 1920x1080
Additional Comments:
And Most Importantly, Why Are You Upgrading:
These are the core components are currently have. Been running into issues when I edit videos, using photoshop. Need to know if I am better off upgrading parts or building a new rig
Include a list of any parts you have already selected with descriptively labeled links for parts. Please do not post only links.
The easiest method is to paste the label on one line and then paste the link below it.
Example:
Logitech 920-000914 Black 106 Normal Keys Wired Ultra-thin Illuminated Keyboard - Retail
www.newegg.com
Looks like:
http://www.newegg.com/Product/Product.aspx?Item=N82E16823126043
Links can also be created using the following format: paste the url here ] paste the label here
The paperclip button on the toolbar gives this: http://www.newegg.com/Product/Product.aspx?Item=N82E16823126043 paste the label here
Example:
Overclocking: Maybe
Example:
Are you a human?
Looks like:
Example:
