Help me build a recording system!
iLoveRAM
79
(Sry about my english i did write this in a hurry..)
Ok so i started planing to build a gaming/recording pc.
Im planing to buy parts from my local shop(the shipping & revenue from international sites are big..)
I did enter the costum prices in pcpartpicker so you can check out the parts.
I dont have a specific budget but im planing to spend around 1000$ (the lower the better)
http://pcpartpicker.com/p/DPBRMp
CPU: The legendary battle between i5 4690K and FX8350.
Im an Intel fanboy so i choose intel but i never had an amd pc and if Amd is better with a
lower price then i would rather take fx8350 than 4690K.
Im planing to use my PC for gaming/editing/recording.
My shops cpu list: http://www.edigital.hr/procesori-c412.html
(Use a translator if needed 1USD=6.33kn)
Motherboard:I have no experiance with motherboards.
Im not planing to overclock.
Help me choose one:
https://translate.google.hr/translate?hl=hr&sl=hr&tl=en&u=http%3A%2F%2Fwww.edigital.hr%2Fmaticne-ploce-c383.html
RAM: I choose crosair over hyperX the difference is 20$.
But is there a big difference?
GPU: Im not planing to save on the GPU!
Im going to spend as much as i can on the GPU!.
Storage: Any HDD will do.
But i need a smaller SSD for windows and recording.
Powersuppy:Recommend me anything.
My shop:
https://translate.google.hr/translate?sl=hr&tl=en&js=y&prev=_t&hl=hr&ie=UTF-8&u=http%3A%2F%2Fwww.edigital.hr%2Fnapajanja-c405.html&edit-text=&act=url
I can choose the case & optic drives myself.
Help me build a good system 😀
take the 4690k. so much better.
as for mobo, the gigabyte z97x sli is a great feature rich price:features mobo. it will let you add another gpu later on, and supports all the usually z97 stuff.
as for the ram, it doesnt matter, it wont really effect gaming performance.
big boy gpu: the gtx 970 is a GREAT price😛erformance card and i always recommend it to someone in your price range.
storage: a kingston ssdNow 120 gig ssd for 55 bucks is a steal. take it for your os and frequently used programs. a 3tb drive is really nice for a recording setup, because recordings can be really big. anyone will do well, as long its 7200 rpm.
psu: the SeaSonic M12II 620 Bronze is a great psu for the price. see if you can get one, cuz the price it so good...
psu: the SeaSonic M12II 620 Bronze is a great psu for the price. see if you can get one, cuz the price it so good right now.
Hope this helps :)
