[SOLVED] help me build gaming pc
abodeking1
Proper
Nov 9, 2018
104
i builded one with i7 8700 and with high component, but its not worth ..
because the i7 8700 working good with Z mobo although no OC, but still i dont want i7 with cheap mobo .. so i want to downgrade to i5 for gaming. and to upgrade mobo and cpu every 4 years.
can you help me build the optimal pc gaming for good budget ?
full hd 144hz gaming competitive and some good heavy gaming like assassins creed on 80 fps
my build :
i5 8500
16gb ram
coolermaster 212 led
rtx 2070 ? or even wait to rx 3080 ? or rtx 2060
b360 ? i think ist good now because i5 wont be hot like the i7 ..
650W +gold corsair
sharkoon tg5
I can offer you a guideline:
Budget 2x the cost of your processor for your graphics card.
If, by optimal, you mean the strongest, that, today would be a i9-9900K and a RTX2080ti.
A very good gamer would be a I7-9700K and a GTX1080ti.
Both K processors can be overclocked to 5.0 using a Z390 based motherboard.
For a modest budget, a I5-8400 and something like a GTX1070ti.
Do not look to the future.
In a few years, products and prices will change.
Games and your needs may change.
Buy what you need now and perhaps for the next year.
yup exactly i need something good for a few years .. because of that i am not looking for future proof anymore.. i just need good quality components like psu case ssd hdd , the others i will change every 3 4 years ..
yes i will give you one. exactly for you. english language too
http://
1$ = 3.71 ₪ ( 1 dollar is squall to 3.71 new israel shekel "NIS" )
my budget is what you give me for a good decent pc , 144hz competitive. 80 frame others.. something for 4 yeras .. gpu i can upgrade after 3 years !? no problem
I got lost in that link you sent over, some parts are just crazy expensive while others are just lost among all the old stuff and the site isn't refined. I still tried my best to get you a compact system.
thank you so this pc will cost me 1751.07 $
the gpu makes it so expensive like 754.31$
haha I told you ours is so expensive !
