Help Me Build My First Computer
xjaex250
9
Hi there I'm new to this site and i was wondering if i can get some help on my build heres what it looks like what do you think? i don't want bottlenecks ext
everything compatible?
what graphics card world you recommend? i was thinking
XFX Radeon HD 7850‎ ?
ASUS Z87-A ATX SLI Motherboard
Intel Core i5 4670K Unlocked Quad Core Processor
Zalman Z11 Plus Mid Tower ATX Case Black 4X5.25 1X3.5 5X3.5INT
Corsair Vengeance Blue CMZ8GX3M2A1600C9B 8GB 2X4GB DDR3-1600 CL9-9-9-24 Dual Channel Memory Kit
Kingston SSDNow V300 120GB 2.5in SATA3 LSI SandForce Solid State Disk Flash Drive SSD
Corsair-650 tx-650 watt psu
thanks in advance
You should get an aftermarket cooler (I would highly recommend the hyper 212 evo.)
You should also get a 2-3TB Seagate barracuda.
No $200-$300 GPU can run games smoothly at 4k. If you do insist on 4k get a 4GB 760 and buy a 2nd for sli later and it will do it decently.
For sli 760s you should get a 750 watt psu.
Also your missing a disk drive.
hi there is this a good card?
http://www.tigerdirect.ca/applications/SearchTools/item-details.asp?EdpNo=8442221&Sku= thx i want to spend like
300-500 i want to be able to hook up to 4k monitor.....possibly run games ultra settings? thx
