Build Advice Help me build my first computer ?
LeeXy41
26
Hello, I'm planning to build a PC with this specs But I don't know which one is better so please help me guys before I regret my decision choosing between this two.
1.
AMD ATHLON X4 860k
GT 730 2GB DDR3
DDR3 x2 8GB hyper fury
Generic 300 watts PSU
asus a58m-k
Samsung Evo SSD 500GB
Or
2.
AMD A10 PRO 7800B with R7 Graphics
asus a58m-k
Appreciate any helps in advance
Do you already have these parts or is there a set reason of your choices. At least if you choose the 860K you have some wiggle room to over clock. But there are extremally cheap used newer systems out there that have 4x bang for the buck.
Reactions: LeeXy41
Hello, I currently have the motherboard My brother gave it to me to help me ease up building my first PC cuz my budget rn is very tight But now I'm stuck choosing between those two specs, I tried searching online for benchmarks but couldn't find anything.
So should I choose the first one?
  • AMD A10 PRO 7800B with R7 Graphics
  • MMX
  • 3DNow!
  • SSE
  • SSE2
  • SSE3
  • SSSE3
  • SSE4A
  • SSE4.1
  • SSE4.2
  • AES
  • ----------AVX
  • BMI1
  • FMA3
  • FMA4
  • AMD64
  • CLMUL
  • CnQ
  • NX bit
  • AMD-V
  • XOP
  • ABM
  • TBM
  • F16C
  • Turbo Core 3.0
Thinking about it a little deeper ---AVX--- on the AMD A10 PRO 7800B.
But again some newer used PC are dirt cheap.
1.
AMD ATHLON X4 860k
GT 730 2GB DDR3
asus a58m-k
Or
2.
asus a58m-k
It really don't matter at todays standards both are pretty much so obsolete unless your just watching YouTube or something.
Hello, I know all the spec I mentioned is like horribly old on todays standard of PC's, But I'm not really into gaming too much yet I play OW 2 and Stardew valley just to waste my free time.
Right now I just want a pc that can do work stuff like opening multiple tabs PS, words and slightly enough to run games that I mentioned on something 60 fps-ish.
Probably when I have enough money to spend in the future Ill build a good Pc , But right now Ill start from the bottom and work my way up :)
So which is better 1 or 2?
Thanks for replying my post! Appreciated it.
  • MMX
  • 3DNow!
  • SSE
  • SSE2
  • SSE3
  • SSSE3
  • SSE4A
  • SSE4.1
  • SSE4.2
  • AES
  • ----------AVX
  • BMI1
  • FMA3
  • FMA4
  • AMD64
  • CLMUL
  • CnQ
  • NX bit
  • AMD-V
  • XOP
  • ABM
  • TBM
  • F16C
  • Turbo Core 3.0
So it will the best pick is the 2nd one?
Hard to tell you to move forward on this build but at the same time you will only be out $12.99.
Find a GTX 970 there dirt cheap and your at least on your first step in your PC journey .
Reactions: LeeXy41
