Build Advice Help me build my first gaming/work PC for about $3000 ?
Jun 20, 2025
8
4
15
I finally saved enough money for my first PC. Can you please evaluate my choice and tell me if any mistakes were made?
In general, I want good performance from a PC in some specific tasks (mostly fast compilation, because with my current laptop it takes about 15-20 minutes to build a project even in unity-build mode), but I would also like to be able to play modern games at medium-high settings in 2K. So here is what I come up with.
Approximate Purchase Date: This week or next.
Budget Range: About $3000
Hardware:
  • CPU: AMD Ryzen 9 9900x. As I understand it preforms slightly worse than Ryzen 7 9800X3D in gaming, but wins in tasks, which require multithreading.
  • GPU: Gigabyte GeForce RTX 5070. As I understand without it's AI features it has the same raw performance as the same series from previous generation. So I would probably get RX 9070XT, but in my region it is ridiculously overpriced (like x2 from the cost of 5070), the same situation is with 5070 Ti.
  • Motherboard: Gigabyte X870 Aorus Elite. My main concern about this motherboard is if I'm not mistaken I can only install 2 M2 NVMe SSDs (one in CPU lane and one in chipset lane) without blocking GPU from using 16 PCI lanes.
  • SSD M2 PCI 4.0x4 (2TB): Kingston Fury Renegade or SSD Kingston KC3000. Don't know if it is the right choice. But honestly I would prefer durability than fast speed, maybe Samsung 980 Pro is the way to go.
  • RAM DDR5 (2x16GB): G.Skill Trident Z5 Neo CL 30T. Do I understand correctly that 6000MT/s actually means 3000Mhz and it will not be bottle necked by my CPU?
  • PSU: Montech Titan Gold 1000W. According to this tier list it is pretty solid PSU. I've alse read that it is better to add additional 15%-20% to watts, that system actually requires, which is, as I understand, is 750W for RTX 5070. Is it correct?
  • Cooling: DeepCool LQ360 or Arctic Liquid Freezer III.
  • Monitor: LG 27GS85Q
Will be very grateful for any help.
Users are advised to stylize their thread with info asked of in this thread;
and the community will chime in with worthwhile suggestions. This site and the majority of it's userbase are located in the USA, so suggestions made on this thread might not be the same if you're located outside of the USA = brand and product availability can and will vary due to region.
Finally saved enough money for my first PC. Can you please evaluate my choice and tell me if any mistakes were made?
Approximate Purchase Date: This or next week
Budget Range: About 3000$
Hardware:
What country are you located?
Reactions: lim1nale
I'm in Poland now
Cost cutters. Also check Amazon Poland and Morelle for prices.
https://www.ceneo.pl/184409028
Montech Century II 850W
https://www.ceneo.pl/170132384
Patriot Viper Venom DDR5-6000 32GB (2x16GB) CL30
https://www.msi.com/Motherboard/X670E-GAMING-PLUS-WIFI
https://www.ceneo.pl/163720241
MSI X670E GAMING PLUS WIFI
Reactions: lim1nale
Add storage.
MSI X670E GAMING PLUS WIFI 1 009,00zł
https://www.mediaexpert.pl/komputer.../procesor-amd-ryzen-7-9700x-oem-100-000001404
AMD Ryzen 7 9700X 1 279,00zł
https://www.proshop.pl/Chlodzenie-C...zenie-powietrzem-procesora-Max-27-dBA/3293293
ID-COOLING FROZN A620 PRO SE 159,00zł
Patriot Viper Venom DDR5-6000 64GB (2x32GB) CL30 779zł
https://www.ceneo.pl/182505384
Gigabyte WINDFORCE SFF RTX 5070 Ti 16GB 3 849,00zł
Montech Century II 850W 467,00zł
https://www.ceneo.pl/158398727
Montech AIR 903 BASE 317,41zł
LG Ultragear 27GS75Q-B.AEU 799,00zł
Reactions: lim1nale
Fish tank case =/ For $3000 you can fit in 64GB of RAM and a RTX 5070 Ti 16GB if you pass on ARGB aesthetics. Just curious but does Unity Build benefit from more cores or would a Ryzen 7 9700x be comparable to the Ryzen 9 9900x?
I don't really understand what is tank case (in shape of tank :) )? Ryzen 7 9700x is only slightly cheaper in my region than 9900x (about 7%), but looses to 9900x in every characteristics
Reactions: Why_Me
PCPartPicker Part List
CPU: AMD Ryzen 9 7900X 4.7 GHz 12-Core Processor (€319.80 @ Amazon Deutschland)
CPU Cooler: Thermalright Phantom Spirit 66.17 CFM CPU Cooler (€50.89 @ Caseking)
Motherboard: MSI MAG X670E TOMAHAWK WIFI ATX AM5 Motherboard (€262.99 @ Computeruniverse)
Memory: G.Skill Flare X5 64 GB (2 x 32 GB) DDR5-6000 CL30 Memory (€211.59 @ Proshop)
Storage: Kingston Fury Renegade 4 TB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive (€288.90 @ Alza)
Video Card: Asus PRIME OC GeForce RTX 5070 Ti 16 GB Video Card (€879.00 @ Computeruniverse)
Case: Lian Li LANCOOL 216 ATX Mid Tower Case (€87.34 @ Amazon Deutschland)
Power Supply: Montech CENTURY II 1200 W 80+ Gold Certified Fully Modular ATX Power Supply (€135.89 @ Caseking)
Total: €2236.40
Generated by PCPartPicker 2025-06-21 10:33 CEST+0200
