Approximate Purchase Date: Next Week
Budget Range: £650 after Shipping
System Usage from Most to Least Important: Gaming, Watching Movies and also to get through Uni
Are you buying a monitor: Yes but not through this Budget.
Parts to Upgrade: I need everything from the Case..
Do you need to buy OS: Yes
Preferred Website(s) for Parts: www.ebuyer.com
Parts Preferences: Intel
Overclocking: Yes
SLI or Crossfire: What would you suggest?
Your Monitor Resolution: 1024x768, 1280x1024 my computer monitor is old so i haven't a clue, probably one of these..
Additional Comments: I would like quite a fancy case E.g. the Coolermaster Storm with a window.... I would need it to be quiet, some LED Lights and liquid cooling... I hope to Play Guild Wars 2 on Max settings and push out high FPS!
And Most Importantly, Why Are You Upgrading: My computer is probably over 4 years old.. I play WoW atm on all the lowest settings and only get 15fps.. my computer can't even download GW2 and i'd want my new computer to get me through Uni.. So just over the budget can be reasonable if worth it!
Thanks!
Overclocking: Yes
Thanks!
