Hi,
I am planning to build a custom PC.
Purpose: It is used for business & general use. It is NOT used for gaming.
Operating system: Windows 7 or Windows 8 (Which one is better?).
I want to use the computer for:
1) Watching Movies.
2) Open Office.
3) Light use of Photoshop, Dreamweaver.
4) Browsing.
5) Productivity software(running in background)
6) VPN(also running in background)
7) E-mail.
8) Few light weight software(around 25-50MB)
I expect it to perform the following way:
1) The windows should load quickly.
2) The applications should load fast.
3) Should have wifi capability
Budget: I do not have a budget. However, it would be nice if it is as cheap as possible without sacrificing performance.
I have done some research and found the below:
-Memory: DDR3 SDRAM (I am confused whether to buy 2GB or 4GB)
-Hard disk: 120GB SSD (I do not store much application in my hard disk). I have heard SSD is better than HDD as it does not have rotating parts.
-Processor: I have chosen Intel as my brand. However, I am not sure which one to buy.
-Graphics Card: It is not necessary for me.
-Motherboard: I do not know which one to buy.
-Cooling: I am a silent guy and hence prefer a cooling system which makes less/no noise.
-USB: I want USB 3.0 ports. (3 ports)
-Size of the computer: I would prefer it to be medium sized.
-Monitor: I would prefer monitors which offers a clear display and not harmful to eyes(I wear spectacles).
-Please mention a reputable vendor.
-Power supply: After seeing my requirements, please suggest a suitable power supply which keeps my computer healthy
Thanks for your time. Any help, no matter how small, will be appreciated
1) Watching Movies.
2) Open Office.
4) Browsing.
7) E-mail.
