so, i wanna build this pc,
mobo:asus f2a55-m lk2 plus
cpu: amd a8-6600k
ram: kingston hyperx fury 2x4gb ddr3
gpu: geforce gtx 750 ti
hdd: 1tb
power supply: 600w+
haven't really decided on the brands of some component yet, also i am very worried that this might not work, cause, the hyperx fury is not compatible with a55 chipset, also the geforce gtx 750ti is pcie 3.0 and my mobo has 2.0
i am from the philippines and this is what i can afford for now, i will upgrade this little by little, so is the pc good to go? please tell me if there is gonna br a problem, thanks
cpu: amd a8-6600k
hdd: 1tb
power supply: 600w+
