Hello, I am building a PC and I would like you to help.
Here is the complete part list I am thinking of getting: http://pcpartpicker.com/list/6CrdCy
Note that I would like to use my old XFX 650W PSU and I dont know if that will be enough, or will I have to go and get a new one. I will be doing some overclocking and I'm kinda new to it so I don't really know too much about it.
I will also be using my old SSD and HDD and will be upgrading that later in the future.
I considerd buying the Asus PG278Q monitor, and while it may sound like a perfect choice (1440p, G-Sync, 144hz, 1ms, TN), many people have had big problems with that monitor, as I have heard, and they had to get 3-5 monitors to get a decent one (dead pixels, backlight bleeding etc.) Then I came across the Acer XB271HU (1440p, G-Sync, 144hz, 4ms, IPS). The only "bad" thing about it is the 4ms response time because of the IPS panel, but I dont know if this difference would make such a huge difference. I simply can't find any other 1ms TN monitors with all of the options that I desire.
The main concern here for me is the PSU. I hope you can help me in building my PC!
