Build Advice Help Me Build My Pc
Dec 31, 2020
81
I'm planning on building a PC with a core i3 3240 (Third generation), 4 GB DDr3 RAM, Zebronics h61 motherboard.
I've got a 710 2GB DDr3 from my old pc, which I'm planning to install too.
Is my configuration correct? Will I face any issues?
Will A 450 Watt PSU be okay?
punkncat
Ambassador
I am honestly not sure. The Zebronics site has almost zero for information. Looking elsewhere it appears that it supports 2nd and 3rd gen Intel, so if it's native to 2nd gen it will likely need a BIOS update to support third. I didn't see anything on Zebronics website indicating support, BIOS revisions, compatibility list, etc.
Given the pricing for new i3, which would be a far better performer, it might be worthwhile to look into. Might be a good idea to post what your budget and needs are. Folks here are great at compiling builds.
Eximo
Ambassador
H61 would have been for second gen Intel, so you might need a BIOS update prior to installing the 3240. So safest to get a 70 series board like H77, Q77, Z75, Z77 or look at a 2nd gen CPU to be absolutely certain.
GT710 is barely a video card, but certainly usable and faster than the Intel HD 2500, though if you looked at a little newer CPU, you could forego the GPU at all.
450W PSU is fine, even less would be acceptable, something like 250W. But that is poor planning for future upgrades.
Reactions: helper800
helper800
I do not know your budget or situation but if you could afford it I would highly recommend something like this as a baseline for windows 10 and modern applications. The 10100 or 10400 can be swapped in to save a bit more money if needed;
PCPartPicker Part List
CPU: Intel Core i5-11400 2.6 GHz 6-Core Processor ($188.99 @ B&H)
Motherboard: Asus PRIME H510M-E Micro ATX LGA1200 Motherboard ($94.99 @ Newegg)
Memory: G.Skill NT Series 8 GB (2 x 4 GB) DDR4-2400 CL15 Memory ($44.98 @ Newegg)
Storage: Team CX2 512 GB 2.5" Solid State Drive ($49.99 @ Newegg)
Case: Cooler Master MasterBox Q300L MicroATX Mini Tower Case ($39.99 @ Newegg)
Power Supply: Antec Earthwatts Gold Pro 550 W 80+ Gold Certified Semi-modular ATX Power Supply ($72.00 @ Amazon)
Total: $490.94
Generated by PCPartPicker 2021-05-07 13:17 EDT-0400
Reactions: Why_Me
Total: $490.94
Kudos ^^ That could very well be the best sub $500 build I've seen in a long time.
logainofhades
Total: $490.94
That case has terrible airflow, and that motherboard is going to need some air moving over it, since the VRM's lack heatsinks. That ram is really too slow. Since it supports it, with an 11th gen chip, 3200 ram should be used. I made some changes for faster ram, and better airflow, without going too much more expensive.
Memory: Patriot Viper Steel 8 GB (2 x 4 GB) DDR4-3200 CL16 Memory ($53.99 @ Amazon)
Case: Cougar MX330-G Air ATX Mid Tower Case ($52.99 @ B&H)
Power Supply: EVGA SuperNOVA GA 550 W 80+ Gold Certified Fully Modular ATX Power Supply ($64.98 @ Amazon)
Total: $505.93
Generated by PCPartPicker 2021-05-07 15:01 EDT-0400
helper800
Total: $505.93
That kit of ram would likely run at 2933 and I was trying to make it as cheap as possible given the information in the op. The case airflow is not terrible, its just not really good. Its in the middle of the pack. The front of the case has too much stylized venting in the front inhibiting what could be really great airflow.
