Build Advice Help me build my PC!
Jun 6, 2024
6
Hey folks!
I want to build a PC mainly for architectural works, so most of the time i'll be using rendering engine.
I've chosen the cpu and gpu that is i7 14700k and 4070ti.
But I'm indecisive about ram !
Should I take ddr5 or to, 4 stick ram or 2. How it gonna affect my performance, which brand should i take etc etc.
Kindly enlighten me on this issue,
Also suggest me some good motherboard.
My whole budget is around $1800
You want 2 sticks of ram. 4 sticks of ddr5 still doesn't work very well. The 14700k's 4 extra E cores aren't really worth another $70 over the 13700k. Honestly unless you need a system now, I would wait till Ryen 9000 launches this month.
PCPartPicker Part List
CPU: Intel Core i7-13700K 3.4 GHz 16-Core Processor ($329.99 @ Best Buy)
CPU Cooler: Thermalright Frost Commander 140 BLACK 95.5 CFM CPU Cooler ($39.90 @ Amazon)
Motherboard: ASRock Z690 Steel Legend WiFi 6E/D5 ATX LGA1700 Motherboard ($159.99 @ Amazon)
Memory: G.Skill Ripjaws S5 64 GB (2 x 32 GB) DDR5-6000 CL30 Memory ($192.99 @ Newegg)
Storage: Samsung 980 Pro 2 TB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive ($169.99 @ Amazon)
Video Card: MSI GAMING SLIM GeForce RTX 4070 Ti 12 GB Video Card ($709.99 @ MSI)
Case: Montech AIR 903 MAX ATX Mid Tower Case ($75.00 @ B&H)
Power Supply: be quiet! Pure Power 12 M 850 W 80+ Gold Certified Fully Modular ATX Power Supply ($99.90 @ Amazon)
Total: $1777.75
Generated by PCPartPicker 2024-07-06 18:25 EDT-0400
Here's a build with more cores and RAM with less GPU a bit over the budget. I dont know exactly what you are trying to optimize for. Are your tasks more CPU or more GPU?
CPU: Intel Core i9-14900F 2 GHz 24-Core Processor ($529.00 @ Amazon)
CPU Cooler: be quiet! Dark Rock Elite CPU Cooler ($99.90 @ Amazon)
Memory: G.Skill Ripjaws S5 96 GB (2 x 48 GB) DDR5-6400 CL32 Memory ($319.99 @ Newegg)
Storage: Acer Predator GM7000 2 TB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive ($139.99 @ Amazon)
Video Card: MSI VENTUS 2X BLACK OC GeForce RTX 4060 Ti 16 GB Video Card ($449.99 @ Amazon)
Case: Fractal Design Pop XL Air ATX Full Tower Case ($79.99 @ B&H)
Power Supply: SeaSonic FOCUS GX-850 ATX 3.0 850 W 80+ Gold Certified Fully Modular ATX Power Supply ($109.99 @ Amazon)
Total: $1888.84
Generated by PCPartPicker 2024-07-06 20:12 EDT-0400
Reactions: Why_Me
CPU: *Intel Core i7-14700 2.1 GHz 20-Core Processor ($349.99 @ Best Buy)
CPU Cooler: *ID-COOLING FROZN A620 PRO SE 58 CFM CPU Cooler ($29.99 @ Amazon)
Motherboard: *MSI PRO Z790-A MAX WIFI ATX LGA1700 Motherboard ($239.99 @ Amazon)
Memory: *Silicon Power XPOWER Zenith Gaming 64 GB (2 x 32 GB) DDR5-6000 CL30 Memory ($179.99 @ Amazon)
Storage: *Acer Predator GM7000 2 TB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive ($139.99 @ Amazon)
Video Card: *Gigabyte WINDFORCE OC GeForce RTX 4070 SUPER 12 GB Video Card ($599.99 @ B&H)
Case: *MagniumGear Neo Air 2 ATX Mid Tower Case ($59.99 @ Newegg)
Power Supply: *SeaSonic FOCUS GX-750 ATX 3.0 750 W 80+ Gold Certified Fully Modular ATX Power Supply ($89.99 @ Newegg)
Operating System: *Microsoft Windows 11 Home OEM - DVD 64-bit ($119.99 @ Amazon)
Total: $1809.91
*Lowest price parts chosen from parametric criteria
Generated by PCPartPicker 2024-07-06 20:53 EDT-0400
Total: $1777.75
Thank you mate!
Total: $1809.91
Thank you <3
Reactions: Why_Me
Total: $1888.84
It depends on the software. But both are needed, the more vram and cuda core the better. But nvidia outperforms amd in most cases. And for ram 64gb 5600 is enough for now , more would be overkill. would later upgrade to 128 if needed. Though most of the software doesn't need 128.
Reactions: helper800
In that case this would be my recommendation:
CPU: Intel Core i7-14700 2.1 GHz 20-Core Processor ($349.99 @ Best Buy)
CPU Cooler: Thermalright Phantom Spirit EVO 69 CFM CPU Cooler ($49.90 @ Amazon)
Memory: TEAMGROUP T-Create Expert 64 GB (2 x 32 GB) DDR5-6000 CL34 Memory ($179.99 @ Newegg)
Video Card: Zotac GAMING Trinity GeForce RTX 4070 Ti SUPER 16 GB Video Card ($789.99 @ Newegg)
Total: $1859.83
Generated by PCPartPicker 2024-07-07 01:21 EDT-0400
