I have to choose here.. first of, i have to choose 8 GB of 1866 G.Skill ram or 16 GB 1600 Corsair ram..
second, i have to choose a CPU. The 3570k, 2600k, 2700k or the 3770k.. I'm a 3D animator / gamer. I'm going with a MSI 660 ti PE/OC, and i'm planing on OC it even more. I'm not going with a aftermarked CPU cooler right now, and the CPU is going to run a 100% in many hours, multiple times a week. which ram should i go for, and what is the difference between 1866 and 1600 MHz?? And which cpu would be best for 3D rendering out of the box? (most value per. dollar) Most of my friends says the 3570k, but I would say the 2600k/2700k.. (the 2700k is about 35 USD cheaper than the 2600k here, for some reason) I want a experts opinion
Thanks!
also! which case would you recommend? I want the best cooling included with the case as possible! and keep it under 150 USD.. and i wouldn't mind seeing a fan controller, and LED's
and if possible a LED switch
here is some cases i have looked at.
Cooler Master HAF 922 Black
Zalman Z11 Plus Black
Fractal Design Define R4
Cooler Master HAF XM
Nzxt Phantom 410 Black
Nzxt Hades MidiTower Black
Cooler Master Storm Enforcer
Zalman Z9 U3
Thermaltake Overseer RX-I Black
Corsair Vengeance C70
BitFenix Colossus MiditowerWhite
Antec Dark Fleet DF-30 Miditower Black
Antec P280 Black
Thermaltake Chaser MK-I FullTower Black / Side ...
Zalman Z9 Plus MidiTower Black / Side Window Panel
Nzxt Phantom 410 White
Thanks! also! which case would you recommend? I want the best cooling included with the case as possible! and keep it under 150 USD.. and i wouldn't mind seeing a fan controller, and LED's
and if possible a LED switchhere is some cases i have looked at.
Zalman Z9 U3
Antec P280 Black
