Help me building a pc
melihool
6
This is first time building a pc so i need some help:
Will my broken laptops HDD work in Dektop?
Will the parts fit?
How will it perform?
Current Build:
Ryzen 5 1400
Asus B-350M A Prime 3200 Mhz OC mATX
Galax GTX 1050Ti EX O.C.
AeroCool V2X Devil Red Mid Tower
Aerocool VX 500W
Corsair 8GB Vengeance Lpx DDR4 2400mhz CL16
My broken laptops 1tb HDD
Not a bad build but a few pointers:
1. That Power Supply is pretty low-quality, i suggest you look into a Corsair CXM or SeaSonic S12-II Series Power Supplies for a good budget.
2. Try get some faster RAM if possible, Ryzen really benefits from it. 2800-3200 is ideal as far as i know.
3. The RX 570 is much stronger for only a little more, i suggest you check it out.
The build should be good for 1080p 60 FPS in around Medium/High settings, if you can get the RX 570 it will be even better. The HDD from your laptop should work fine provided it still works, it might just be slower since laptops drives are typically a lower RPM but nothing major. Hope this helps :)
In my opinion, this Case and PSU would be a better pairing:
PCPartPicker part list: https://pcpartpicker.com/list/YmJ2Fd
Price breakdown by merchant: https://pcpartpicker.com/list/YmJ2Fd/by_merchant/
Case: Corsair - 100R ATX Mid Tower Case ($49.99 @ Amazon)
Power Supply: Corsair - CXM 450W 80+ Bronze Certified Semi-Modular ATX Power Supply ($29.99 @ Newegg)
Total: $79.98
Generated by PCPartPicker 2017-05-08 04:40 EDT-0400
you Laptop HDD will work in a desktop build as they should be standard SATA drives, your case has 2.5inch mounting so that shouldn't be an issue either
Bro thanks for your reply i will look out for these case and power supply but im living in Turkey and it looks like they arent available here.
Hmm do you have a link to the store(s) you'll be using ideally? I can take a quick look at what's a good budget Power Supply.
I dont think you will understand Turkish but take a look 😀
http://www.sinerji.gen.tr/
http://www.hepsiburada.com/
http://www.teknobiyotik.com/
Yeah wasn't easy...
Since you were already looking at the Aerocool VX, this is only a little bit more but i'm not familiar with the currency so unsure if this is quite expensive for you. But out of all the cheaper pages, i'd go with this one. SilverStone Strider 500W 80+ Silver. Link > http://www.sinerji.gen.tr/silverstone-strider-80plus-sertifikali-500w-guc-kaynagi-tek-12v-kanal-38a-akim-pmu401945
Thanks bro i will go with it but i wont change the case.Its a bit expensive but 80+.Thanks for helping.
