A aleksandar.mladenoski123 Prominent Mar 3, 2018 136 0 680 Mar 7, 2018 #1 help me make my game run better so i can play it Also if you have any other ways of making it run faster id love to see your solution!
CountMike Titan Oct 31, 2015 35,668 3,834 147,990 Mar 9, 2018 #2 ll you can do is to set resolution in the game itself. You didn't say which kind oh computer you are running it on. Upvote 0 Downvote
CountMike Titan Oct 31, 2015 35,668 3,834 147,990 Mar 9, 2018 #3 All you can do is to set resolution in the game itself. You didn't say which kind oh computer you are running it on. You probably need better one. Upvote 0 Downvote
A aleksandar.mladenoski123 Prominent Mar 3, 2018 136 0 680 Mar 9, 2018 #4 CountMike : ll you can do is to set resolution in the game itself. You didn't say which kind oh computer you are running it on. yes i need a better pc, and the mas res i can lower it down is something 1024 x 720 i think i need lower! Upvote 0 Downvote
CountMike Titan Oct 31, 2015 35,668 3,834 147,990 Mar 9, 2018 #5 Maybe you can try in compatibility mode, should be able to drop to 800 x 600 but I'm not sure game would allow it. Upvote 0 Downvote
A aleksandar.mladenoski123 Prominent Mar 3, 2018 136 0 680 Mar 10, 2018 #6 CountMike : Maybe you can try in compatibility mode, should be able to drop to 800 x 600 but I'm not sure game would allow it. nope. Doesnt allow it. Tried changing the res of the display, but nope. It forces it to 1024x7.... Upvote 0 Downvote
