Help me choose a case
noMercy19
14
I'm really struggling to choose a case.
Features I am looking for.
    1. Mid-sized tower
    2. 360mm Radiator support in front and top
    3. Tempered Glass side panel
    4. Offset top radiator mounting holes to maximise clearance from mobo heat sinks and RAM.
    Tempered Glass side panel.
    5. I want to see my front fans from the front so a grill-type design is best for maximum airflow.
A the moment I'm looking at the Thermaltake View 31 but the front only has 1 intake vent on the side which makes me worried that it will choke the fans.
A Thermaltake core P7 has a ton of radiator support and looks awesome with a huge open air tempered glass side panel. It also has enough expansion slots for 4-way multi GPU setups. If you want to save...
A Thermaltake core P7 has a ton of radiator support and looks awesome with a huge open air tempered glass side panel. It also has enough expansion slots for 4-way multi GPU setups. If you want to save some money, the P5 looks awesome too and also has tons of radiator support.
As already mentioned above, the Corsair 460X and 570X are also excellent and beautiful cases. (and RGB, which automagically makes them better in ever way, right?)
If you want to completely remove any chance of top clearance (if you have an ATX board), you can get a Phanteks Enthoo Elite. Tempered glass, enormous, and beautiful.
It supports up to a 560 radiator in the front, up to a 480 radiator in the top, bottom, and midplate. It also supports up to a 360 radiator in the side, and a (mere) 140 in the back.
By the way, yes the P5 and P7 are open air.
