Ok let us start with I read in the forum A LOT about g-sync ,free-sync and adaptive about HZ about refreshrate , frames per second , resolutions etc.......
What I cannot seem to understand (I hope someone can explain and answer my questions ) the following :
1 - What is the relation between FPS and Refresh Rate ( HZ ) of a monitor ?
2- How do one affect the other ?
3- What happens when I have FPS higher than HZ and what happens the other way around ? (which is better?)
4- What is the relation between resolution and FPS ?
and here the next questions are the same as above ?
I have a setup which is with GTX 1070ti and i7 8700k 16 ram 3200..
looking for a monitor that can give me the best smooth play ..
As far as I have decided it is 144hz and a 1080 res.
So what happens when I play a game that will run with 50-60 fps on 144 hz monitor does matter if it is 144 hz or 60hz ?am I wasting the rest of the HZ ? and what happens when I play a game that will run with 300 fps ?
I know that I have too many questions but I cannot decide which is best for gaming and would it be better if i get 1440p monitor with 144hz eventhough my games will run with 60-70 fps ?
or should I go for 1080 144hz and at least gurantee that my FPS will be Higher ?
I THANK EVERY PERSON TOOK THE TIME TO EVEN READ MY THREAD !!!!!! 😍 😍 😍
