Help me choose a monitor
User1001
32
Hello everyone, i want to buy a new monitor and i have these options locally. I'm a media analyst and do casual gaming. Thanks in advance:
Philips V-line 240V5QDSB 24-Inch LED Monitor
https://www.amazon.co.uk/d/Monitors/Philips-240V5QDSB-00-V-line-24-Inch-LED-Monitor/B011J6PFYO
Acer G246HYLbid 23.8 inch Monitor
https://www.amazon.co.uk/Acer-G246HYLbid-23-8-inch-Monitor/dp/B00FB6C3GM
Dell SE2416H 24" Screen LED-Lit Monitor
https://www.amazon.com/Dell-SE2416H-Screen-LED-Lit-Monitor/dp/B012AQICKG
Dell E2417H 24" WLED LCD Monitor
https://www.amazon.com/Dell-E2417H-WLED-LCD-Monitor/dp/B01KR1AMLI
It's a run between acer and the second dell one which are both IPS. So is phillips but has atrocious response time. Acer is at 5ms and second dell at 8ms. Second dell has a shade higher PPI. Their other stats are very similar. Acer has hdmi and dvi and Dell has vga and display port. Figure out what you need of these, as that'll probably decide it. Also can check reviews for both for longevity and warranty length.
The first dell is also IPS and has 6ms response time, It's a higher grade model but is 1 year older than the second Dell.
