Question help me choose a monitors
Aug 3, 2024
Basically I need a new monitor, I play FPS games somewhat competitively. Until now I've had a benq 144hz and I don't really care about colors (my benq colors were very bad so I'm used to it). I have ~200e budget. If you have the time to check some of them or recommend me ones, thank you.
- I don't need more than 1920 x 1080
- flat, not curved
- 165hz + prefferably, if there isn't anything good under 200 I'll go again with 144hz I guess
https://uk.pcpartpicker.com/user/vinnyq/saved/#view=FTDWrH - this is what I found until now
Hey there,
Well have a read here: https://www.rtings.com/monitor/reviews/best/by-resolution/1080p-full-hd - This might help.
Given you are playing competitively, then something high HZ is preferable. Prob 240hz or so. But this really depends on your system and how fast your CPU is. What are your system specs?
At 1080p I'd stay away from 27in screens. The pixel density is low compared to a 24in 1080p panel. With a 27in, depending on how far you're seated from the screen you may see pixels close up. It might necessitate moving further away from the screen. A 27in 1080p panel has 81ppi. A 24in 1080p monitor has 92ppi, so better pixel density. Looks better.
I'd also stick with IPS rather than VA as the panel type. IPS has better colours and very little ghosting. VA has better contrast, but can suffer with motion blur a little more.
