Help me choose a PC case
macc4s
30
Cooler Master HAF X is the best case for airflow, cable management and it has mad room for upgrades.
Cooler Master HAF X
other options
Fractal Design Define R4
Thermaltake Commander MS-I Epic Edition
Cooler Master HAF X
other options
I really like the design of the h440, its really slick, it has a side window, it hides the PSU, you can display your ssd, good air flow, good cable managagement, all in all that case is perfect
I wanted to get the Corsair 780T Graphite Series Windowed Full Tower ATX Gaming Case with LED Fan for PC - Yellow, but it was out of my budget.
http://www.amazon.co.uk/Corsair-CC-9011045-WW-Graphite-Windowed-Performance/dp/B00HSY20DQ/ref=sr_1_34?ie=UTF8&qid=1424002531&sr=8-34&keywords=case+corsair
Already builded two systems with the Raidmax Cobra, great design and air flow, plenty of room for expansion + its affordable.
http://www.amazon.co.uk/Raidmax-ATX-502WBG-Cobra-tower-ATX/dp/B00BCZZRFU/ref=sr_1_1?ie=UTF8&qid=1424786673&sr=8-1&keywords=raidmax+cobra
I would recommend the Phanteks Enthoo Pro or Enthoo Luxe if you want the best cable management with some great airflow options. Various sites review it and think it's one of the best if not the best case.
