Help me choose between these 3 builds!
breje203
4
So I'm gonna buy a new PC today, and I want to know which of these builds I need to pick.
Build 1:
Intel Core i5 7600K
MSI Z270 Gaming Plus
Corsair Vengeance RGB 16GB DDR4-3000
MSI GeForce GTX 1070 Gaming X 8G
Corsair RM550x
Seagate BarraCuda 1TB 7200RPM
Samsung 850 EVO 250GB
NZXT Noctis 450
Cryorig H7
TOTAL: 1438,75 euros
Build 2:
Intel Core i7 7700K
MSI GeForce GTX 1060 Gaming X 6G
Corsair RM550x
NZXT Noctis 450
Cryorig H7
TOTAL: 1431,70 euros
Build 3:
AMD Ryzen 5 1600
MSI X370 Gaming Plus
Corsair RM550x
NZXT Noctis 450
Cryorig H7
TOTAL: 1393.70 euros
As you can see the builds are very similar. Only the CPU and GPU differ.
I'm gonna use this PC for gaming. 1920x1080p
are you doing the PC yourself or buying a pre built one ?
Check shops in Germany most will send to Belgium.
This site sends to Belgium and has the i5-8600K in stock
https://www.hardwarecamp24.de/PC-Komponenten/Prozessoren/Intel-So-1151v2/INTEL-Core-I5-8600K-6x-36GHz-Boxed-ohne-Kuehler-Sockel-1151-2-Co::30466.html
The i7 8700K is harder to find in stock.
The Z370 motherboards are available in most...
Go for Z370 motherboard and Gen8 CPU , there is no point in getting older Gen.
get GTX 1070 , Z370 motherboard and i5 8600K or i7 8700k.
as for your choices , if this PC is for gaming , the first one with GTX 1070 and i5 7600k
I considered going for a Gen8 CPU build, but it is not available to buy in my country (Belgium).
The Z370 motherboards are available in most shops.
mindfactory.de , computeruniverse.net also send to Belgium.
