Question Help me choose Case
TechQuestion1
Great
BANNED
Jan 13, 2020
134
Hello, thanks for helping.
This are my PC components:
OS : Windows 10 64Bit V 1709
CPU : INTEL Core i7 8086k 4GHz
GPU : NVIDIA GeForce GTX 1080 Ti OC
Ram/Memory: : Kingston 32 GB DDR4 4000MHz
Display/Monitor : ASUS PB287Q 3840x2160 70Hz
Storage/Harddrive : SAMSUNG SSD 970 Pro NVMe M.2 1TB
MotherBoard : MSI Z370 A Pro E7B48IMS.280
Power Supply : Corsair CX 600
Cooler : BeQuiet Dark Rock Pro 4 250 w tdp
My current pc case is old and have very bad ventilation because its full metallic and closed with only 2 fans
Heat isnt good for pc so im really looking into finding a good case for a good price. silent will be good but less heat aswell
Thanks !!!
Vic 40
Polypheme
Ambassador
Here i am again unable to make a choice.
I just dont know which one to pick.
You can help me say which one you would take and most important, why?
For me they all look good, i might upgrade my GPU in future so more power isnt wrong.
https://www.amazon.de/Corsair-Carbide-Gaming-PC-Gehäuse-schwarz/dp/B079JVTPJK/ref=sr_1_7?__mk_de_DE=ÅMÅŽÕÑ&keywords=corsair+gehäuse+silent&qid=1583083685&sr=8-7
https://www.amazon.de/quiet-Gehäuse-schwarz-gedämmt-BG021/dp/B01N7PGIPS/ref=pd_sbs_147_1/257-4619072-7626034?_encoding=UTF8&pd_rd_i=B01N7PGIPS&pd_rd_r=53793007-78af-4a3c-8337-0d75bd81d252&pd_rd_w=T2Iiy&pd_rd_wg=qXSTO&pf_rd_p=c8718c55-fb13-473f-a41c-592a17ad3468&pf_rd_r=MBMF2N3VC9PW9QXDZXDW&psc=1&refRID=MBMF2N3VC9PW9QXDZXDW
https://www.amazon.de/quiet-Window-Gehäuse-orange-BGW20/dp/B06WVRDC41/ref=sr_1_4?__mk_de_DE=ÅMÅŽÕÑ&keywords=be+quiet+gehäuse&qid=1583083977&refinements=p_72:419117031&rnid=419116031&s=computers&sr=1-4&th=1
https://www.amazon.de/quiet-Gehäuse-Silent-silber-BGW07/dp/B014VZD8G2/ref=pd_sbs_147_4/257-4619072-7626034?_encoding=UTF8&pd_rd_i=B014VZI3GC&pd_rd_r=53793007-78af-4a3c-8337-0d75bd81d252&pd_rd_w=T2Iiy&pd_rd_wg=qXSTO&pf_rd_p=c8718c55-fb13-473f-a41c-592a17ad3468&pf_rd_r=MBMF2N3VC9PW9QXDZXDW&refRID=MBMF2N3VC9PW9QXDZXDW&th=1
https://www.amazon.de/quiet-Silent-Gehäuse-Seitenfenster-BGW30/dp/B07HKPN3QB/ref=sr_1_2?__mk_de_DE=ÅMÅŽÕÑ&keywords=be+quiet+silent+base+800&qid=1583085680&sr=8-2
https://www.amazon.de/quiet-Temperglas-Seitenfenster-Beleuchtung-BGW23/dp/B0773NWQNQ/ref=sr_1_1?__mk_de_DE=ÅMÅŽÕÑ&keywords=be+quiet+silent+base+700&qid=1583085664&sr=8-1&th=1
Those 6 links is which i cant choose.
Most important:
1 - Quiet
2 - Ventilation
3 - Price
Instead of looking at those do i have another choice,
BEQAB be Quiet! Pure Base 500 PC-Gehäuse aus: Amazon.de: Computers en accessoires
some reviews,
Be Quiet Base 500
Again Be Quiet Base 500
How about the antec P110 silent?
https://antec.com/product/case/p110s.php
Once it holds your parts and has at least two 120/140mm front intakes, you will get decent cooling airflow.
Prefer 140mm fans which move more air at lower rpm and are quieter.
A single 120mm rear exit fan is there mostly to direct airflow.
I would also include a washable front intake filter as a requirement.
It helps to keep your parts free of dust.
Ultimately pick the case that looks the best to you.
TechQuestion1
Great
BANNED
Jan 13, 2020
134
