help me choose cooler
PrimalMonitor
Commendable
Jun 9, 2016
16
my Processor is throttling because the stock intel cooler lost one of its (white leg) that attach to motherboard so its kinda loose , im only have budget around 30-40$ right now the only available thing on my trustful online shop was , deepcool gammaxx 400 white for 27$ , thermal right true spirit 120 for 32$ , hyper 212 evo for 40$ , raijintek aidos for 29$ , people suggest me the H7 but its out of stock (h7 is around 36$ here)
What CPU you have? If you don't OC just get Gammaxx 400, it's cheaper and does very well.
There's a tendency for people to over recommend the H7, you are unlikely in need of it if you just want a replacement for stock cooler.
intel core i3-3220
GA-B75M-D3H
2x4gb Avexir
zotac gtx 1050ti dual fan
2x2tb toshiba 7200rpm HDD
Super Flower Platinum King 650w
Cube Gaming Weiss Case
ambient temperature in room is over 28-34celsius (using AC is around 14-23celsius) , i live in equator line
thanks for your suggestion , looks neat though 😀
