Help me choose correct PSU
chomaxa1995
40
Hello everyone I need your help to choose new PSU for my pc, I upgraded video card and my PSU cant take it and it always turns off my spec are: amd phenom 2 x4 955 be on gigabyte GA-MA790X-UD4 ddr2 800mhz 6gb and video card is MSI AMD Radeon R9 270X Gaming 2GB GDDR5, my budget is 50$ in thi list of video cards my video card says that it needs 500w PSU but I don't know much of them and I want your help if it requiers more money I could spend more but if there is PSU under or 50$ please suggest it to me
The first two tiers on that list are the best units for any spec. Those are the ones you want to get, you don't want to skimp on a PSU. Lower quality units tend to not deliver everything that's listed on the box and your mileage may vary, sometimes they last forever, sometimes they last a month, the thing is, with low quality PSUs, the chance that it will take out all your other components with it when it goes is much higher.
https://www.youtube.com/watch?v=Ezk9OA7aKOE
The PSU I linked is a nice one. After the 20...
You need a 500w psu with two 6 pin pcie connectors.
$50 will not usually buy you a good psu.
Look for a tier 1 or 2 unit from this list:
https://community.newegg.com/eggxpert/computer_hardware/f/135081/t/45344.aspx?Redirected=true
Start with Seasonic, XFX, and Antec.
I have no problem overprovisioning a PSU a bit. Say 20%.
It will run cooler, quieter, and more efficiently in the middle third of it's range.
A PSU will only use the wattage demanded of it, regardless of it's max capability.
geofelt thanks for answer you mean choose one of 1 or 2 tier units ?
and jossrik what do you think about your suggestion I don't know mcuh about PSU and can both of you tell which will be best for my spec pc ?
The PSU I linked is a nice one. After the 20 dollar rebate, it's actually a pretty good deal.
yes you right I understand I will go with your suggestion and buy this:
http://pcpartpicker.com/part/xfx-power-supply-p1650gts3x
