[SOLVED] help me choose cpu!
Jul 17, 2019
20
okay so i have a e8400 and i wanna upgrade looking at my budget i can buy i5 650 or i5 2400 the price difference is not that much so which one should i buy?
You're going to need to replace the motherboard and(possibly) the ram if you want to go outside of the LGA775 socket.
You might also want to shoot us a budget and your location for ease of sourcing parts.
actually im buying a completely new pc not upgraing that one my budget is 20k pkr in pakistan imma also buy 750ti if money is left
For 20,000PKR, you're looking at an entry level concurrent gen AMD system. In fact for 720p gaming you can manage with the Ryzen APU's. Might want to list your current specs like so:
CPU:
Motherboard:
Ram:
SSD/HDD:
GPU:
PSU:
Chassis:
OS:
and then post a preferred site for purchase.
