Jeff_120 Honorable Dec 11, 2016 330 8 10,795 Dec 23, 2018 #1 I have the choice between MSI Gaming Plus B450M and Gigabyte A320 S2H Which one is better for the 2700 with moderate to high (not very high) OC?
Solution madmatt30 Dec 23, 2018 You can't overclock on a a320 board, it's also ill equipped to deal with a ryzen 7. So simply put the B450m gaming plus is the only sensible choice. Luckily its also a fairly decent board.
madmatt30 Titan Ambassador Jan 1, 2013 24,571 647 91,240 Dec 23, 2018 Solution #2 You can't overclock on a a320 board, it's also ill equipped to deal with a ryzen 7. So simply put the B450m gaming plus is the only sensible choice. Luckily its also a fairly decent board. Upvote 0 Downvote Solution
