Help me choose grahic card
askara
246
i just bought a pc from packardbell. quad core 2.3 GHZ. 4g ram and Geforce g100. runing window 7 RC and it is pretty bad at gameing. it has low framrate at devil may cry 4 at low. so i was going to buy a grahic card. having done a bit of reaseach i was confused like nividia rebranding, how higher number doesnt mean better and power suplyy etc. and i dont know which is the best, and compatible. so please help me choose a grahic card. my buget is around £100 or below. oh and does it matter if is it from pny or bfg etc?
here is full spec on the pc: http://support.packardbell.com/uk/item/?pn=PT.U090X.013&g=1400
monitor and speaker has seperate plug-dont know if that matters
ps will the game run faster if i downgrade to xp?
so what is the max power i can get? is say 230V and 2amp at the back. does that mean i can use card with minium power supply requirment 460W or below?
and do i have a 6pin pci-e?
i dont no if i am right but power(watt)=voltage x amp and on my back it say 230v and 2 amp, so i guess my psu is 460watt. meh.. i am probably wrong.
shut down your computer, unplug it, remove your side panel, find your power supply. There will be a sticker on it that lets you know what it's rated at, look at the connectors, is there a 6 pin pcie plug? Blow the dust out while you're in there.
hmmm 250 watt?....but the Nvidia G100 require 300Watt. did i read the wrong thing?....geez guess i have to but a new psu. can anyone recommend me one? or does any one will fit?
HD4670 require 400watt also so if i can run that card then doesnt mean i can run all other too? like 9800gt
ohh i think i have a 6pin pci e
maybe a 4770 they use really little electricity for a great performance (40nm) and they are getting more frequent again (earlyer they were out of stock)
my psu is FSP FSP250-60HEN 250W can anyone tell me if i can run 4770 or 4670 as they require 400w.
would it explore if i overload the psu?
performance wise is there a bigh diffrent between 4670 and 4770? and what nvidia card they are equal to?
guess i have to upgrade a new psu.
i'm not really sure how big the difference between the two but many people recommending 4770. u can check reviews and benchmark if u are interested. as for your second question have u read tom's best graphic card for month yet? at the end of the article lies the answers for your question. :)
