G
Guest
Guest
Hello guys,
I'm trying to chose between these 2 motherboards:
MSI B85M-P33 (60 €)
MSI H87M-E33 (80 €)
I have been checking for hours what they can offer. The second one gives the possibility to use RAID. Both don't support the use of SSD for HDD caching. The cheapest one also doesn't have vPro which is a functionally to remote access the computer and iSIPP Eligible(I don't really know what this is, yet).
Honestly I don't need any of these. What I need:
Socket 1150
PCI 3.0 x16
2x Sata 6gb/s
DDR3 1600Mhz
And both can provide me that. I don't plan go for SLI/CrossFire, OC, upgrades. However I do plan(I know you will start laughing) having a 300€ and 200€, GPU and CPU respectively.
The system will be mainly used for gaming and streaming.
The big question is, if these weak mobos will somehow affect my system performance? If yes, how much?
I tend to choose the other components first and then just go for a mobo where I can fit them.
Also, I know AMD's CPUs have great relationship between Performance/Cost. I dare you to try convince me to get one 😛
Thank you.
MSI B85M-P33 (60 €)
MSI H87M-E33 (80 €)
Socket 1150
PCI 3.0 x16
2x Sata 6gb/s
DDR3 1600Mhz
Thank you.
