Trying to decide between two builds, different color schemes and case. Both builds have the same price (or very close).
#1: https://pcpartpicker.com/user/Yashr914/saved/MXB3bv
#2: https://pcpartpicker.com/user/Yashr914/saved/TMmcYJ
Parts are basically the same or of the same spec, just having trouble on which build would look nicer and could use some outside feedback. Both builds match my setup and are equal in performance. Thanks for any help given.
EDIT : Completely forgot about this one but I feel that this should be an option too.
#3: https://pcpartpicker.com/user/Yashr914/saved/TCgWD3
