Help me choose my Z87 motherboard pls
Which motherboard would you pick?
  • AsRock Z87 Extreme 4
    Votes: 0 0.0%
  • Asus Z87-A
    Votes: 1 50.0%
  • Gigabyte Z87X D3H
    Votes: 0 0.0%
  • MSI Z87 G45 Gaming
    Votes: 1 50.0%
  • Total voters
Bertco
4
Hi everyone,
I've been tinkering at a gaming pc build the last few weeks and think I've pretty much reached the point where I'm satisfied and ready to order the components.
Only one part I'm still questioning, the motherboard.
The PC will mainly be used to play games at 1080p.
I plan on doing a bit of overclocking, around 4.2MHz.
I've narrowed it down to 4 boards, all in the same price range.
Research at sites like this one and newegg resulted in a lot of conflicting user reviews which made me even more confused.
http://pcpartpicker.com/part/asrock-motherboard-z87extreme4
http://pcpartpicker.com/part/asus-motherboard-z87a
http://pcpartpicker.com/part/gigabyte-motherboard-gaz87xd3h
http://pcpartpicker.com/part/msi-motherboard-z87g45gaming
Below is a link to the build so far. Feel free to tear it apart.
Wensenlijst 1150€ intel OC GTX770 van Bertco
Thanks!
I voted for the MSI. I have the lower version of this MB and it OC's quite easily to 4.6 GHz. I am very happy with my MSI MB. It appears that the MSI is also the lowest price from the links that you posted. I have no experience with the others.
Yogi
I would go with the asrock z87 extreme 4 as i have been using it for 8 months now and never had any problems with it....i paired it to an i5 4670k and it has been happily running at 4.6ghz....
Hope I Helped You
