I want a gaming PC that can play the games like Battlefield 3 and Crysis 3 and such at High - Ultra settings while not letting the FPS drop lower than 30 fps. I also want it to be future-proof so that i dont have to mess with anything in it for I don't know, 5 years? More? Less? I dont know. I have also been researching parts and I managed to create my own rig in PCPartPicker.
The part choice? Build? The thing I put together in PCPartPicker is here.
The overkill PSU is because I may want to CrossfireX / SLI the cards ( I'm not sure, NVidia or ATI / AMD )
What do you guys think?
Approximate Purchase Date: Whenever; preferably so that it can arrive before 26th of June
Budget Range: $1500 - $2000
System Usage from Most to Least Important: Most Important: Serious Gaming Least Important: Everything Else
Are you buying a monitor: Yes
Parts to Upgrade: New build
Do you need to buy OS: Maybe
Preferred Website(s) for Parts: newegg.com, amazon.com
Parts Preferences: AMD GPU or Nvidia GPU, Intel CPU
Overclocking: Yes
SLI or Crossfire: Maybe
Your Monitor Resolution: 1920x1080
Overclocking: Yes
