Help Me Choose Parts
crazy359
532
I am buying from this website. www.lucomuters.com I have already bought 3 computers from them and i love their prices.
My budget is $650 - 680
Do alot of gaming but on a small monitor. Use photoshop ALOT.
Here is my best pick.
CPU:
http://www.lucomputers.com/site/view_part.asp?id=13991
MOTHERBOARD
http://www.lucomputers.com/site/view_part.asp?id=11721
RAM
http://www.lucomputers.com/site/view_part.asp?id=13631
HDD
http://www.lucomputers.com/site/view_part.asp?id=2352
DVD ROM
http://www.lucomputers.com/site/view_part.asp?id=6053
GPU
http://www.lucomputers.com/site/view_part.asp?id=10698
PSU
http://www.lucomputers.com/site/view_part.asp?id=12133
CASE
http://www.lucomputers.com/site/view_part.asp?id=13508
TOTAL $669
PLEASE GIVE ME SUGESTIONS
I would like another case and if if fits budget and has a window then neons.
I love people like you. It clearly says my budget is $670 and u giv me this.
LG DVD Burner - Bulk Black SATA Model GH24NS50 - OEM $25.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16827136177
RAIDMAX SMILODON ATX-612WBP Black 1.0mm SECC Steel ATX Mid Tower Foldout MB Computer Case With 500W Power Supply - Retail 94.99
http://www.newegg.com/Product/NewProduct.aspx?Item=N82E16811156062
Western Digital Caviar Blue WD6400AAKS 640GB 7200 RPM SATA 3.0Gb/s 3.5" 69.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16822136218
ASRock M3A770DE AM3 AMD 770 ATX AMD Motherboard - Retail $59.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16813157176
SAPPHIRE 100245HDMI Radeon HD 4850 512MB 256-bit GDDR3 PCI Express 2.0 x16 HDCP Ready CrossFireX Support Video Card 99.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16814102824
G.SKILL Ripjaws Series 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model F3-12800CL9D-4GBRL $104.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231277
AMD Phenom II X4 955 Black Edition Deneb 3.2GHz Socket AM3 125W Quad-Core Processor Model HDZ955FBGMBOX - Retail 159.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16819103808
Grand total 670.33
You can use the power supply with the case for now its a pretty decent power supply and the phenom 2 black edtion is one of the best they have
Saint19 setup is good too where as he focoused on a better GPU i focoused on the better CPU i would get the better CPU for now especially since the x4 955 can overclock a good bit. The 4850 is a great card and will play almost anything at high settings at most res.
Lets say in a year you want to upgrade you go with a beefer GPU and a bigger PSU
That is amazing what you can get for that money.
Im sorry dude for wasting your time but I am buying from www.lucomputers.com
CPU: Athlon 620
Motherboard M4A785MEVO (If you go new, go DDR3)
http://www.lucomputers.com/site/product_parts_detail.asp?class=31&pro_class=31&id=13649&cid=31
Ram
http://www.lucomputers.com/site/product_parts_detail.asp?class=29&pro_class=29&id=9525&cid=29
The rest of your components look good, so overall I am raising the price slightly by upping motherboard and ram, however it is more of a long term investment.
Their prices are good for somethings and quite soso for others... as long as they have good shipping and communications go for it.
Or go for me if you are located less then 1 hour away from Montreal 😛
The reason I am buying from them is because they are 15 min away from me. 16km.
So everyone is satyin athlon 620 is best for my case.
I have thought about it........will a x2 250 do ok?
