Help me choose please
Jan 2, 2019
So basically im going to build my first pc and after alot of searching i have come up with two different cpus
Cpu:intel i3-8100
Motherboard: gigabyte H310M
Or
Cpu: Ryzen 2200g
Motherboard: asrock B450M-HDV
both will have a Zotac gtx 1050 ti mini 4gb and 16gb (8gb x 2) of ram.
I'm not sure about the psu but i think both will be a evga br 80+ 450w broze rated psu
Im only gonna play League of legends, Cs:go and rainbow six seige
If anyone can help me choose or recommend a different mother board pls do so, just remember its a budget pc, thx
Do you have the 1050ti already? Because if you're buying, then rx570 is better
If you can purchase i3-8100... Then I don't see why you don't get ryzen 2600, not much more for a premium line cpu.
Otherwise I would take the 2200g over the i3, as it can be overclocked and you'll have good performance out of that.
Uhhh 2200g has 4 physical cores as well.
You can have a look at you'tube gameplay comparisons, the i3-8100 is a few frames ahead of a non overclocked 2200g.
Ryzen system gives a much better future prospect. And you save quite a bit of cash for the same performance (when you're on a budget).
Both are good even I also using Ryzen 3 2200g on Asus ex a320m gaming. And it is really good performer . But Intel core i3 8100 runs games of some more FPS.
But you are also right about overclocking. And even AMD can Run RAM at 3000+ MHz on cheap motherboards. But for Intel we have to buy Z series motherboard. That are really expensive. And AMD providing excellent cooler thats why we don't need to spend extra on CPU cooler.
All and all AMD is good Choice here. And Intel too. But you get more benefits with AMD
