Question Help me choose the best build
Apr 19, 2019
37
I'll be honest, both of the lists seemed pretty horrible to me.
Than show me how it's done master. I really need those headphones and mousepad (my desk is made of metal) but you can change anything else that fits the budget (even if you beyond a bit it's fine I'll try to save up a little more money if needed but I don't guarantee anything)
No, you don't need more than a 550 watt PSU. Make no mistake, the RMx is excellent and better than the CXM, but if you want to save money, go with the CXM. You'll want an ATX size MB for that windowed case. The mATX will look too small. You could save some by going with the Ryzen 5 2600 and overclocking it. Your FPS will be nearly as good as the 2700x, but you'll need an aftermarket cooler to overclock it.
CPU: AMD - Ryzen 7 2700X 3.7 GHz 8-Core Processor (€211.00 @ Amazon Italia)
Motherboard: Gigabyte - B450 AORUS ELITE ATX AM4 Motherboard (€101.41 @ Amazon Italia)
Memory: *G.Skill - Aegis 16 GB (2 x 8 GB) DDR4-3000 Memory (€84.60 @ Amazon Italia)
Storage: Crucial - MX500 250 GB M.2-2280 Solid State Drive (€57.08 @ Amazon Italia)
Storage: Toshiba - P300 2 TB 3.5" 7200RPM Internal Hard Drive (€64.80 @ Amazon Italia)
Video Card: *Zotac - GeForce RTX 2070 8 GB AMP Extreme Core Video Card (€420.00 @ Amazon Italia)
Case: SHARKOON - TG5 RGB ATX Mid Tower Case (€72.00)
Power Supply: Corsair - CXM 550 W 80+ Bronze Certified Semi-Modular ATX Power Supply (€74.90 @ Corsair)
Monitor: AOC - C24G1 24.0" 1920x1080 144 Hz Monitor (€218.89 @ Alternate Italia)
Other: HyperX Cloud Alpha Pro Gaming Headset (€99.95 @ Amazon Italia)
Other: TITANWOLF - XXL Tappetino per Mouse da Gioco | Gaming Mousepad Super Grande 900 x 400mm | Pad con Base in Gomma Antiscivolo | Spessore 3mm | Nero | Modello: Diamond (€12.95 @ Amazon Italia)
Total: €1417.58
*Lowest price parts chosen from parametric criteria
Generated by PCPartPicker 2019-04-21 22:38 CEST+0200
OR THIS:
CPU: AMD - Ryzen 5 2600 3.4 GHz 6-Core Processor (€159.52 @ Amazon Italia)
CPU Cooler: Deepcool - GAMMAXX 400 74.34 CFM CPU Cooler (€28.00 @ Amazon Italia)
Total: €1394.10
Generated by PCPartPicker 2019-04-21 22:48 CEST+0200
Apr 19, 2019
37
Total: €1417.58
OR THIS:
Total: €1394.10
What about the tmx?
Apr 19, 2019
37
Look at the wattage at the top of your pcpartpicker list, only 304 watts. And this:
http://www.realhardtechx.com/index_archivos/Page362.htm
I didn't realize that on your list you and switched from the 2700X to the 2700 + cooler for overclocking. That is fine.
I assume that you like that case or that you already own it. I did not change it.
Yeah I know about the wattage but I actually checked a calculator and it says around 500w and is recommending me a 650w psu so I'm just gonna go with that
Apr 19, 2019
37
I didn't realize that on your list you switched from the 2700X to the 2700 + cooler for overclocking. That is fine.
In this one I've included all the fans and all the other USBs that I can use.
https://outervision.com/b/1dPJDr
About the case:
1)Looks kinda cool (I'll take the wite led version)
2)is affordable
3)has 4 fans included
Can't ask for more
Apr 19, 2019
37
I made 2 variants, one to peak the budget for best performance and one to be best value for money.
Also, all the prices listed on pcpartpicker are not accurate. A 2700X can not be bought for 211€ like the first build would suggest.
Peformance: https://it.pcpartpicker.com/list/w63yhy
Value: https://it.pcpartpicker.com/list/MX9rKB
All the prices in these lists were roughly correct when i checked.
BTW can you explain what's wrong with this one: ( https://it.pcpartpicker.com/user/imMAXAM/saved/tLQ7TW )?
I just wanna learn
Apr 19, 2019
37
Yes, those wattage calculators overcompensate because they assume you might pick up a really crappy low budget PSU that falsely advertises its capabilities. The PSU sellers also want to make more profit by selling you a larger one. Try this calculator which is generally better:
https://outervision.com/power-supply-calculator
However, 650 watts is fine and the RMx is a really excellent unit.
About the case:
2)is affordable
Can't ask for more
LOL
Both of your builds have video cards which are much worse that the RTX 2070, therefore the gaming will be worse.
I am not an expert on the monitors and just accepted what was already chosen.
Finstar
I just wanna learn
  1. Aftermarket cooler is not needed with the Ryzen cpus and if you want to overclock, you'll want something beefier than that.
  2. The MX500 M.2 at 84€ is somewhat overpriced. I chose the P1 because 1, it's NVMe (faster) 2, it has better gb per € than many other SSDs.
  3. Toshiba HDDs overall are not very good, loud and unreliable.
  4. The RTX 2070 is a very bad gpu for it's price, it only performs 15-20% better than the RTX 2060 which generally is around 150€ cheaper, furthermore there's the Vega 56 which costs even less and outperforms it.
37
  4. The RTX 2070 is a very bad gpu for it's price, it only performs 15-20% better than the RTX 2060 which generally is around 150€ cheaper, furthermore there's the Vega 56 which costs even less and performs nearly as well as the RTX 2070.
1) I won't overclock anything (I'm kinda inexperienced and I don't actually need to overclock it)
2)I'll change it right now
3)guess you're right but I don't know which HDD to chose i always think about the barracuda
4)i actually will switch to the Vega because I never play on full settings anyway (I get sick when I do because I'm kinda poor sighted on one eye and too perfect graphics annoy my eyes since they see it in "different" ways and lowering the graphic kinda evens the difference)
And I guess since you didn't mention it the monitor is fine?
Finstar
Barracudas are good drives, fast (for a HDD), quiet and reliable.
The monitor you chose is fine, it supports freesync so it'll work great with the Vega 56.
The one i suggested has higher resolution with lower refreshrate which mostly comes from my own preference, since using a low resolution display gives me a headache after a while.
Reactions: imMAXAM
Apr 19, 2019
37
It's the other way around for me lol
Apr 19, 2019
37
So it's finally complete!!!!! THANKS!!!
Similar threads
