Help me choose the better case.
Vishana
15
Trying to decide which out of these 2 cases is the better one. I originally had 5 or 6 I was considering but I am down to these 2 . They are both silent type cases...I am wondering what you all think is going to give me the best value in the long run.
Wondering also for you personally is having a window on your PC case is a deal breaker or not. Considering the Black version's both with and without the Window. Any Help much appreciated!
https://www.amazon.com/NZXT-Tower-Matte-Black-Window/dp/B015401JQY/ref=sr_1_3?ie=UTF8&qid=1474500837&sr=8-3&keywords=NZXT+440
https://www.amazon.com/Phanteks-Eclipse-P400S-Silent-PH-EC416PSW_BK/dp/B01BLY9MTI/ref=sr_1_1?ie=UTF8&qid=1474500872&sr=8-1&keywords=phanteks+p400s
I decided not to get the Fractal Define S or R5 and decided against the Corsair 400q I think it was.
I recommend the H440. This comes from its superior stock fan setup and amazing radiator support, and also because I own the case and am very impressed with its build quality.
