help me choose the power supply for my rig
Varun Reddy
196
AMD FX- 8350 4ghz. ( wanna over clock it to 4.3 ghz )
corsair vengeance 16 gb ram ( 1600 mhz )
Nvidia Gigabyte GTX 760 2gb overclocked version .
asus m5 a97 LE R 2.0 mother board .
23 inch monitor ( HDMI . 1080 resolution )
cooler master hyper 212 evo
3 LED xtra flow fans . 2 120mm fans .
2 had disks seagate 7200 rpm
1 dvd drive
cabinet cooler master 690 II advanced .
will all the above components be satisfied with the below :
Seasonic S12II 620 Watts PSU ...
http://www.flipkart.com/seasonic-s12ii-620-watts-psu/p/itmd5xz46hjzzrax?pid=PSUD5XZ4GCGRASAY&otracker=from-search&srno=t_3&query=seasonic+s12ii+520+watts+psu&ref=ff1ec42f-f6e9-4fcb-8f3a-a6244f209643
thank you in advance for ur valuable time .
your current parts will need 550W exactly, so about a 650w PSU (considering the 80-85% efficiency)
so i recommend a seasonic 750W gold. this is a very good PSU for you now.
but if you are planning on future upgrades, then a 850W is necessary.
yeah i do dota 2 game video edits ... and i already have everything except the PSU 😀
Yes the PSU goes on the bottom of the case and the cables are usually made to be too long so you can zip tie them down around the case to get better airflow.
