Hello,
So few days earlier I have decided to change my PSU since system was crashing on high loads. My old PSU is EPS ENERGON Gaming power supply 650W semi-modular, and as I looked it up on google people were saying that its a junk psu ( correct me if I am wrong.) So I decided to go with CORSAIR CX 650W semi-modular also, but with that one my system refused to boot longer than 1 second, so I switched it back to my old psu again and it booted properly but crashed again on high loads. I managed to refund the corsair psu and now I am in search of PSU that will work on my specs and not sbut down my system immediately.
My sytem is 3 years old and after 2 and half years of use shutdowns and restarts began on high loads, its not the temperature, as I checked the temps and changed termal pastes on cpu and gpu, so I suspect its the PSU.
Cpu at idle : 25C
Cpu at load: 48C
Gpu at idle: 50C ( fans only spin at 60C)
Gpu at load: 69C
Pc is clean and cables are all checked.
Power outlets are fine.
Ram is reseated and Cmos battery is changed.
Here are the specs:
motherboard: Gigabyte ultra durable h110m
cpu: Intel i5 6500 3.2ghz 3.2ghz 4 cores
gpu: XFX AMD RX 480 8gb vram
ram: 2x 8gb Hyper x
hard drive: 1x Toshiba 1tb drive
Coolers: cpu stock cooler, 1 front panel intake cooler and double stock gpu coolers
1x 60hz acer monitor
1x keyboard
1x mouse
1x Headset
No speakers
Since Corsair cx650W didnt worked on my machine, I dont know which one to buy for my system and I need help to solve this annoying issue
Mybe its just a faulty one out of the box, But I dont think so it gave the power to the mother board, when I pressed the power button everything lighten up and spinned for a second and then shutdown
The old psu crashes only on high loads.
Thanks for future advices, I appreciate everyones advice
Help!
Cpu at idle : 25C
Cpu at load: 48C
Gpu at load: 69C
Here are the specs:
ram: 2x 8gb Hyper x
1x keyboard
1x mouse
1x Headset
No speakers
