Help me choose the suitable psu
NathanThePro
12
Im new to pc build and still dont know how much watts do I need for my build
SPECS :
Mobo : asus h110m-k
Cpu : intel pentium g4560
Ram : acaper 2400mhz 4gb ddr4
Gpu : gigabyte gt 1030 ddr5 2 gb
Hdd : 500 gb
Case : tecware nexus m
You need only 300w or so.
But, a 450w psu will cost no more and accommodate a future graphics card upgrade as good as a GTX1060.
Buy a quality psu, tier 1/2, no less than three:
https://linustechtips.com/main/topic/631048-psu-tier-list-updated/
FWIW:
I will never again build without a ssd for the "C" drive. It makes everything you do much quicker.
120gb is minimum, it will hold the os and a handful of games.
But, many things default to the "C" drive.
When a SSD nears full, it will lose performance and endurance.
240gb is the recommended minimum.
If you can go 240gb, or 500gb you may never need a hard drive.
You can defer on the hard drive unless you need to store large files such as video's.
It is easy to add a hard drive...
A competent 450W would be easily more than enough.
Power Supply: Corsair - CXM (2015) 450W 80+ Bronze Certified Semi-Modular ATX Power Supply ($29.99 @ Newegg)
Total: $29.99
Generated by PCPartPicker 2018-10-06 23:14 EDT-0400
Get a 550W if there's a good chance that you'll make significant CPU and GPU upgrades.
I would avoid a 100-series motherboard as those motherboards typically need a BIOS upgrade to run a Kaby Lake CPU. I would also try to fit in 8 GB of RAM; it's very hard these days to still recommend 4 GB for budget builds.
I'd also strongly consider a Ryzen 2400g build as an alternative as the integrated GPU is roughly at the level of a GT 1030 already.
FWIW:
It is easy to add a hard drive later.
Samsung EVO is a good choice for performance and reliability.
